ArchiCAD_Man_park
drawing update(repeated) bug
1. I used Archicad28 and Archicad29
2. There is a drawing update bug (repeated).
3. It's been 6 months since this phenomenon occurred. It hasn't been resolved in the past updates.
If you import drawing files from another Archicad into the layout book, there are infinitArchiCAD bug.pngely many drawing updates.
It is saved automatically in this state, and backups are useless.
It's a really terrible bug.
2 Replies 2
Guru
As in the external drawing will get stuck updating?
Can you cancel the update and load the rest of the file?
Your process is to open a Layout, then Place an External Drawing, at which point it gets stuck?
What format is the external file?
You can open said external file normally?
ps. This post in in relation to BIIMCloud SaaS public links apparently? Is that not for sharing outputs, not actual AC files? Is this issue actually related to the sub?
ArchiCAD_Man_park
Q. Is there a delay in the update as in the external drawing?
A. There is no delay. It repeats. Cancel, update, cancel, update... (from 5 to 10 per second)
Q.Can I cancel the update and load the rest of the files?
A. I can't press it because it's been canceled and updated too quickly.
Q. At what point is the process of opening the layout and placing the external drawings fixed?
A. Correct, the external drawing was the step of importing the drawing placed in the other Archicad28 layout book.
Q. What is the external file format?
A. Drawings placed in the Archicad28 layout book
Q.Can I open an external file normally?
A.Yes, this error only occurs when calling.
