elevation and dimension unit differ
Llian
can anyone tell me why my elevation values look like in metric whereas my dimensions are in imperial? how can i change it to imperial ? I've checked my preferences and they are in imperial...
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
9 REPLIES 9
In Project Preferences, there are 2 different things
1. Woking units
2. Dimensions and others
Have you checked both (all of them) ?
Cheers
Llian
Thanks...where is the working units setting?
Llian
i have checked both and they are both in imperial..... i have to redraw again the mesh and elevations...i think this is the 25 th times!
can you attach your working file ? (instead of the image)
thanks
David Maudlin
Llian:
Check Project Preferences > Dimensions > the 5th button from the left.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Steve Jepson
Just a tip. If you do not set the inches dispaly to 0 3/4" you could end up seeing nothing for dimensions less than 1".
By null at 2010-06-28
Steve Jepson
for example this setting does not work.
David Maudlin
Works here.
Steve Jepson
Steve wrote:
Just a tip. If you do not set the inches display to 0 3/4" you could end up seeing nothing for dimensions less than 1".
It depends on your other settings. I was just offering a heads up about it.
This anomaly was already been discussed so I didn’t want to re-state all the conditions where this can happen.
Sorry I can’t remember the topic tile so I could add a link to that thread.
