Llian
furniture symbol...
not sure what happened…it was showing the form of this designer chair on floor plan and then it changed to this simple form. how do I change it?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
1 Solution
Llian
Thank you Laszlo...
I just figured it out by changing the scale sensitive to 1:50 and it is showing the form.
I don't see any setting in MVO for objects other than doors, windows, skylights...
Go to post
3 Replies 3
Maybe the chair has a setting to set its 2D representation based on MVO settings and you changed the MVo settings for Objects to a simpler representation. This could be done by activating a View, since MVO settings are saved with Views and applied when a saved View is restored.
Llian
Thank you Laszlo...
Patrick M
any time it's set to "by MVO", it is going to be controlled by the model view option settings... which are prone to buggy hiccups
