graphic override
Hi!
it seems that when I override fill of building material I loose cut lines between overridden material and the connecting one.
Is there a solution to this problem?
Concrete is overridden in my case and you can see that cut line between brick material and concrete is gone after override is applied.
2 Replies 2
DGSketcher
Legend
I have seen this, it may be a bug.
Does turning on "Show skin separators" solve your problem?
hi DGSketcher!
yes it works when separator skins are turned on.
thank you for the idea.
