‎2015-08-27
07:33 PM
‎2023-05-30
10:03 AM
Rubia Torres
‎2015-08-28 07:36 PM
‎2015-08-28 07:57 PM
‎2015-08-28 08:27 PM
‎2015-08-28 08:44 PM
‎2015-08-28 08:46 PM
‎2015-10-02 09:16 PM
andyb wrote:This does not appear to be working in AC18 6000. We are unable to create Custom settings for grid elements in sections or elevations. I've tried altering this from both the project map and the view map. I've also tested with grid elements placed separately as well as using the grid system. Also tried graphic editing of individual grids in a section window. The changes made in one window are inherited by the others.
Just one more thing- and I apologize if I'm not understanding something- if I open one of my elevation views in my view map, select the grid and open the tool, and hover over the 'custom' setting, I receive the attached message (see below). This is what led me to believe that I could control the hgt. of the column bubble in different views.
‎2015-10-05 12:26 PM
‎2015-10-07 03:40 PM
‎2017-11-22 06:42 AM
laszlonagy wrote:Laszio,
Yes, this seems like a bug. This is how it is supposed to work:
http://helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/user-interface-reference/too...
However, I can confirm that this Custom setting is currently not working in AC19 either.
Also the other field, the Copy from field in the upper right corner of the panel does not work either.
I will report this to Graphisoft.
