help with expression for roof pitch
RandyC
With the new expressions - we should be able to create a label that gives - roof slope -- ie: 4/12 , 5/12 etc.
It should work with-- roof slope = tan(roof_angle)*12
I am unsure of what syntax to use,or if it is possible -- any ideas ?
Thanks Randy
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
poco2013
Mentor
If you want The pitch format of 6/12 etc., the expression would be:
CONCAT ( STR ( TAN ( {Property:Roof/Pitch} ) * 12, 0 ), "/12 - Pitch" )
Both the expression and the element must have the same classification.
Gerry
poco2013
Mentor
Gerry
RandyC
Thank you , worked perfect -- I will need to get my head around classification.
