ā2024-06-23
06:10 PM
ā2024-12-20
02:22 PM
we are creating soffits in each and every room, we use slabs to do so. My hope is to show the soffits (logically) only inner lines , NOT side lines. (looks lame).
How do I HIDE the side lines of soffits so it looks clean? Otherwise, how else do you create soffits but show them on the floor plan/3d properly as well (without side lines?)
Thanks!
ON ATTACHED PHOTO, the red shows where the lines are not desirable, obviously, because that's not how soffits should look like in real or 3d or floor plan..
Operating system used: Mac Apple Silicon Sono,a 14.5
ā
Solved! Go to Solution.
ā2024-06-23 07:21 PM
Rather than 4 separate slabs, you can magic wand (or in the illustration, draw a rectangular slab snapping to opposite corners) a single slab to the interior wall edges... then pet-palette-subtract an offset slab the width of the soffit creating a hole... resulting in a single slab for all soffits.
If you want section cuts to look correct, you could do the soffits with a complex profiled beam. Lots of options, but I don't think you can get rid of the lines for two adjacent slabs in plan (hope I'm wrong).
ā2024-06-23 06:35 PM - edited ā2024-06-23 06:35 PM
another Moderator
ā2024-06-23 06:38 PM
thank you, but will this show line to show the soffits edges, correct? I don't want to eliminate all the lines, only the sidelines.
ā2024-06-23 08:28 PM
That worked! Thank you!
ā2024-06-24 02:33 PM - edited ā2024-06-24 02:37 PM
Yes, it will remove the line for slabs that are touching and have the same surface material and cover fill.
another Moderator
ā2024-06-24 02:36 PM - edited ā2024-06-24 02:39 PM
Yes you can.
Since AC23:
another Moderator
