Since every view, layout set etc has to be identical for it to work, that would be difficult. But you can use a template - if you begin with a current project, just delete all the model items (safest bet is select all in the 3D window and delete) and save it as a template for the next. Then start a new project from that, and you'll have all views, layout sets, publisher sets etc already set up.
