import tpl data in current pln archicad file
Zdenko
what is the work flow to bring in a "master border layout" from the TPL file into a current PLN file? i tried the organizer but will not let me open a TPL. basically i am improving our TPL master file so others can bring in items as needed instead of chasing multiple PLN files. any suggestions?
Operating system used: Mac Intel-based Sonoma 14.5
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
You'll have to just open the template TPL and save as a PLN and then import the master from there.
It seems like an oversight by the product managers that the Attribute Manager can open TPL files but the Organizer cannot.  If we could still make wishes, this seems like an obvious and easy-to-grant one.
One of the forum moderators
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Zdenko
thanks karl! agreed on wishes...
Sequoia 15.1.1
Setup info provided by author
