‎2025-04-07 03:21 PM
If i have a 3d document in a layout it updates the 3d document view after everything thing I do on the layout (example± editing a text inside the layout, add lines etc or even if I go to the internet browser and come back to archicad layouts.
This makes the all process extremely slow.
anyone else has this problem or has a solution ?
thanks
Operating system used: Windows 10
‎2025-04-07 03:31 PM
You can select the view, go to its properties and set the update type to manual instead of auto.
However, if you do this, remember to always update drawings before publishing.
hope this helps.
‎2025-04-07 04:22 PM
Thanks CosminF. Unfortunately, we tried this, but it was a problem with people forgetting to update layouts.
In AC25 this doesn't happen so am pretty sure its a bug
‎2025-04-08 02:55 AM
And have you contacted your local support about this bug to see what they say?
Can they confirm or deny the problem?
If they can confirm, then hopefully they can offer you a solution.
If not, then they should escalate the issue up the chain to GS HQ.
‎2025-04-08 03:56 PM
I have but not have an answer yet.
Was wondering if anyone else had this problem
‎2025-04-10 11:48 AM
Did you try with a new file using only the oob archicad library?
