lineweights
hi there. i am confused about lineweights. is there a way to set up different lineweight settings for different scale drawings? for example, i have a plan that overall i plot at 1/4"=1'-0" and i have set up my lineweights to look a certain way. what if i need to plot a detail of it at say, 1"=1'-0". what would be the best way to handle lineweights so that they look the same in both drawings, no matter the scale? thanks.
8 REPLIES 8
TomWaltz
Ideally you set the lineweights in Plotmaker. You can have different groups of pens for different scales or drawing types.
What many offices to is have several PMKs off to the side, one for each pen set. You just match (eye dropper) the pen set you want, then inject it into your view.
Tom Waltz
If you are printing from ArchiCAD (this is a very objectionalble thought to some) the attributes manager is another way to quickly get the pen setting you want to use for printing at different scales. Pen settings are saved as .att files that you can imprort to use for printing at different scales.
Haneef Tayob
So simple! Now why didn't I know that?
Thanks
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
Djordje
You don't read the Talk regularly
This technique is around forever ... most propagated by the template masters around here.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Hi there. I am using student version archicad. How can I plot my elevations and sections which show lighter lineweight for background lines? How can I show material on the elevation, for example the timber studs on the wall?
Thank you very much.
Djordje
With the elevation marker/line selected, choose Marked Distant area and show the range; the elements behind will be shown with a thinner pen.
If in S/E, you have to have a fill assigned to the material of the walls, and Vectorial hatching on in the Model effects. If you want your background to be hatched too, set it in Distant area options.
If in rendering, the material has to have a proper texture assigned.
HTH,
Djordje
HP Omen
Thank you. But how can I make the texture of the object that i want to render? For example, If I want to make the wall look like bamboo wall?
Djordje
Well ...
... better get Dwight's book, I think.
Making a texture is a job in itself; in the Resources topic, you will find a lot of links pointing to the free textures web sites.
Bamboo is not very easy, but it it good as it is repetitive.
Art•Lantis for example has excellent bamboo and wicker shaders, but that is not what you have asked.
Djordje
HP Omen
