‎2006-01-16
04:16 PM
‎2025-02-07
03:45 PM
Aruzhan Ilaikova
‎2006-01-16 06:05 PM
marta wrote:Ideally you set the lineweights in Plotmaker. You can have different groups of pens for different scales or drawing types.
hi there. i am confused about lineweights. is there a way to set up different lineweight settings for different scale drawings? for example, i have a plan that overall i plot at 1/4"=1'-0" and i have set up my lineweights to look a certain way. what if i need to plot a detail of it at say, 1"=1'-0". what would be the best way to handle lineweights so that they look the same in both drawings, no matter the scale? thanks.
‎2006-01-23 08:33 PM
‎2006-03-17 03:13 PM
TomWaltz wrote:So simple! Now why didn't I know that?
What many offices to is have several PMKs off to the side, one for each pen set. You just match (eye dropper) the pen set you want, then inject it into your view.
‎2006-03-19 05:10 AM
Haneef wrote:You don't read the Talk regularlyTomWaltz wrote:So simple! Now why didn't I know that?
‎2006-04-02 02:11 AM
‎2006-04-02 05:10 AM
Caren wrote:With the elevation marker/line selected, choose Marked Distant area and show the range; the elements behind will be shown with a thinner pen.
Hi there. I am using student version archicad. How can I plot my elevations and sections which show lighter lineweight for background lines?
Caren wrote:If in S/E, you have to have a fill assigned to the material of the walls, and Vectorial hatching on in the Model effects. If you want your background to be hatched too, set it in Distant area options.
How can I show material on the elevation, for example the timber studs on the wall?
‎2006-04-02 10:05 AM
‎2006-04-03 05:23 AM
Caren wrote:Well ...
Thank you. But how can I make the texture of the object that i want to render? For example, If I want to make the wall look like bamboo wall?
