pdf converter lost
I have used my PDF converter on the AC publisher as well as the pm publisher. now it has disappeared. i have no way to publish pdf documentation. is there a way to get this back?
3 Replies 3
If the Amyuni PDF Converter does not show up in your Printers and Faxes folder, it must have gotten deleted somehow.
You can reinstall by going into your C:\Program Files\Graphisoft\ArchiCAD 9\PDF Converterfolder. You'll find a PDF manual there, and an Install folder containing the 'install' program to reinstall.
the amyuni pdf converter is there. when i pull up the publisher and go to the view set side i choose the views i want and then click the drop down arrow for the format to publish in and the pdf is gone. is there a setting i can change to access ths function?
Ah. You've set your publishing set to be a "save as" rather than a "print" set.
You can "save as" PDF, or you can "print" to the PDF driver as you probably know. I believe there is some slight functionality difference, but I haven't used the 'save as' approach, so don't know what it is.
Yes, PDF should appear below Module File.
Your registry might have gotten damaged, I suppose. I'm not positive, but I think that the setting that affects this may be the 'Disable PDF Support' key in the 'Driver Error Patch' folder. (That key should be '0'.)
HKEY_CURRENT_USER\Software\Graphisoft\ArchiCAD\ArchiCAD 9.0.0 USA R1\Driver Error Patch
