2005-02-07 07:23 AM - last edited on 2023-05-26 02:37 AM by Gordana Radonic
2005-02-07 04:20 PM
2005-02-07 05:10 PM
vinayak wrote:Vinayak,
Can i know how to use plotmaker. im not able to import my Archicad drawings onto plotmaker layout window n i need to change the scale for each n every drawings.
2005-02-07 05:23 PM
2005-02-07 05:40 PM
woodster wrote:Woody,
That being said (Dan's comments)... you really are much better off setting up your views in ArchiCAD...
Woody
2005-02-07 05:53 PM
2005-02-07 06:51 PM
2005-02-08 07:28 PM
"Djordje" wrote:
Well ...
For the kind of projects you normally do, it is a good idea to have pre-defined sets of plans at the usual scales (1:50, 100, 200, 500) in the template. Then, if you see that it does not fit, just re-link in PlotMaker. Watch the text and the structural grid markers, though ...
2005-02-08 09:26 PM
I have started sing Plotmaker (after 10 years of delay) and my drawings are imported ok from the AC file. I set the scale of each drawing from within Plotmaker using the drawing settings dialoge box.Part of your problem with text size is because you are changing the scale in plotmaker. The view that you imported must have been set to a different scale. Here are what I consider fundamental steps to take advantage of what plotmaker has to offer.
Nevertheless the TEXT comes out huge.
I struggled to understand the cause and solve it but result was zero.
I am sure that this is a simple matter and I call for help.
I would appreciate any help in this
constantine
2005-02-08 09:37 PM
