We value your input!
plumbing riser diagrams
In AC12 in 3D windows with the "internal engine" set do isometric drawings with 30deg & 15deg guide lines. With AC19 you can go 3D windows, and as was suggest to me, go to "3d documents from 3D..." but you only x-y axis and 45deg. Is this another ability that AC19 has sacrificed or is there a work around to this?
Change the 45 degree setting to 15 degree in the Work Environment. Than Snap Guides will be displayed in 15 degree increments.
Laszlo,
Thanks much, simple fix when you know what your doing, which I have a long ways to go.......Thanks to you it's just got a little bit shorter.
