print trace
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2017-09-07
12:18 AM
2023-05-19
10:10 PM
Gordana Radonic
AC26 MBP OS Ventura
AMD Radeon Pro 5300M 4 GB
Intel UHD Graphics 630 1536 MB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-28 08:38 PM
Dave wrote:Yes, simply by placing two (or more) drawings, each based on a SAVED view, on top of one another on the layout.
Is there any way to get trace reference to show using the publisher set, instead of printing an individual layout by going to "File" then "print"? I typically use the publisher set to print all pdf layouts.
This was the old trick for 20 years or so until we got Graphics overrides in order to get different appearances for different elements in a layout. But, it works for anytime that a single view does not have all of the model elements that you want to show on the layout.
The key is that hotspots are still snappable between drawings on a layout - making it easy to perfectly align two drawings. If no common geometry is showing in each drawing/view for correctly aligning/snapping ... then use the Hotspot tool (asterisk icon) to place a hotspot on the Archicad layer in some obvious location. Hotspots never print, but such a hotspot will always be visible for snapping purposes.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-28 08:40 PM
Dave wrote:That's not really possible if indeed it is a properly saved view in the view map ... and the drawing placed on the layout is created from that view via drag and drop or however.
my other problem is that the trace reference view is set to renovation filter "planned status" but it shows up in the published pdf as "show all".
A proper view, when the settings are examined, has a NAME or value for every single field - and NEVER has "missing" or "custom" anywhere.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-29 09:25 AM
Dave wrote:Are you using publisher to "Print" (to a printer) or creating PDF's? Either way yes. See attached.
Dave wrote:Does it appear correct onscreen before publishing?
Red Canoe Architecture, P. A.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-29 04:06 PM
AC26 MBP OS Ventura
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-29 04:07 PM
AC26 MBP OS Ventura
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-29 09:28 PM
AC26 MBP OS Ventura
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-30 06:14 AM
Dave wrote:What happens if you create a new layout with the view you used for the trace as the drawing... does it print (PDF) with the correct Reno filter?
this is what the pdf looks like. You can see there are a couple houses and some street curb cuts on "to be demolished" status that show up only in the pdf
Not that it will solve the problem, but may help to trouble shoot. I've no idea why it would print different.
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
