2006-11-24 08:48 PM - last edited on 2023-05-19 12:14 AM by Gordana Radonic
2006-12-05 02:08 AM
Future_Architect wrote:it would help to know what operating system and archicad you are using. PDF print/publish/export is a different kettle of fish for each.
Oh I figured it out!!! but errrrrrrr when I open it as a PDF file it appears to be so small... would it be like this when i print? or would it print to the 1:20 scale that I had set?
2006-12-05 02:32 PM
Future...????? wrote:You've already got the answer... In my post before, (perhaps you should read it again??) I outlined the process on how to print to scale from Archicad, and that applies also to how to print to PDF, which in general terms to how to set Publishing to pdf too. I also told how the receiver should setup his printing of the PDF to make it print to scale :
... the person that in turn prints out the PDF will have to check "no page scaling" in HIS print dialog (Adobe Reader?) otherwise Reader will adjust for printer margins again, and the scale will be off.Now, I suggest you check out the Help files and do some work by yourself!
