problems with printing plans
I am not educated in the publishing and master layouts components of ac 10. I need to print plans on 24 x 36. I have a master layout set up to arch D with my drawings on it. my problem is i cannot get the same paper size in the page setup, and i cannot create a PDF file to save to. Any information will help!
4 Replies 4
Stress Co_
Mac or PC?
Marc Corney, Architect
Red Canoe Architecture, P. A.
im on a PC
Stress Co_
Mac here.. sorry, I'm no help.
Thomas Holm
If you have the correct printer driver (or .ppd file) for the printer/plotter in question you should be able to choose it and set the correct page size.
If the driver isn't available, you could in page setup select a page size half as big as your goal and set page scaling to 50%, produce your pdfs and then instruct the printer to scale them up when printing.
The publisher works just like ordinary printing. The important consideration is to set the master layout at a size that works to print at the available paper size, either at 100 % or scaled.
