publish to pdf is gone!
hi,
After the most spectacular system crash & HD wipeout, things are more or less back to normal.... excpet that there is no more PDF option in the publisher, AC10 INT.
Any suggestions?
H
2 Replies 2
try reinstalling the pdf components from the original disk.
Link
It should/could be loaded already, but you just need to reinstall it. Look for and run the install.exe in the ArchiCAD 10> PDF Convertor> Install folder.
Link.
