‎2005-03-04
05:56 PM
‎2023-05-26
12:15 AM
Gordana Radonic
‎2005-03-04 10:25 PM
‎2005-03-04 10:41 PM
‎2005-03-05 12:02 AM
‎2005-03-05 12:05 AM
‎2005-03-05 05:44 PM
you should check with your service bureau to see about using PDFs but absent that, Link's solution will give you one file vs individual PLTs which is what I think you want.Woody, what issues do you foresee with the plotting bureau?
‎2005-03-05 06:38 PM
Regarding, the File method I suggested, is this a bug in 9? I am sure this was okay in AC8.1. I checked the plt file (by importing it back onto the layout) and it's only saving the first page, which is useful to just about no one, which is why it seems like a bug to me. Either that or I am getting confused with a bug/usability issue I have already reported.
‎2005-03-06 11:25 PM
‎2005-03-07 12:29 AM
Nick wrote:If you use the method I described above you do not have to save each file separately. You push the publish button once.
I solved it in Publisher, follow the method that Link suggested except you have to save each file in the folder separately under plot settings.
‎2005-03-07 03:45 AM
