2021-12-06 07:36 PM - edited 2021-12-06 07:37 PM
Hello group. This image is extremely simple, but my question is very technical.
How do I make the wall have only 1 contour projection line? In this picture, I applied the wall view in projection, continuous projection line and no end lines, however I can't find a way to hide both the outer line and the inner line of the wall profile.
I couldn't find anything in the manual that talks about this.
Solved! Go to Solution.
2021-12-07 12:33 AM
I recommend creating a wall composite with only one core element, then you can control the pens to only show on the outside on none on the sides. This would require creating a lot of variants if you have multiple thickness. Otherwise draw a fat polyline around your external building as a 2D outline. If it doesnt suit, I hope you are able to achieve it another way. Best wishes.
Menu>Options>Element Attributes>Composites
2021-12-07 07:53 AM
And just to add that if you do have multiple thicknesses, you can use a complex profile wall instead of a composite. You can control the contour visibility for each edge and still be able to.adjust the wall thickness.
2021-12-06 08:10 PM
Walls have thickness and will always show both lines
2021-12-06 08:21 PM
isn't there some way to hide the interior line?
In my city, project approval only considers the face of the exterior wall.
every time I have to approve a project I have to redo the perimeter with hachure and hide the walls,
2021-12-06 10:24 PM
Not that I'm aware of.
2021-12-07 12:33 AM
2021-12-07 01:18 AM
this was very helpful, thank you very much for the information.
it helped me a lot
2021-12-07 04:26 AM
Please mark the post that helped as the Solution, not your own reply to it...
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2021-12-07 04:38 AM
I have sorted that out.
2021-12-07 07:53 AM
