License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
sections/elevation not displayed correctly
alemanda
I encounter an issue with sections and elevations when I set "display only opening" in MVO for doors and windows.
Under this setting I cannot see windows and doors opening in sections and elevation.
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
Erwin Edel
I only get that with 'opening only' in combination with 'core of load bearing elements only' view in ArchiCAD20, seems like a bug though.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello alemanda,
I gave it a try myself, and I could reach the same state as you did, but I think this is just a rebuild issue.
If you open the MVO window and make changes to those settings, the contours will go missing in the Elevation tab, but if you do a Rebuild & Regenerate (ctrl/cmd+alt+shift+R), they should come back.
If you place these views on layouts as drawings, they should update properly. The Contour line setting shouldn't have any effect on sections/elevations anyway, it's just for the floor plan view contours (as the preview picture shows).
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
alemanda
Thanks Daniel
I hope you're going to fix this rebuild issue ... especially because it seems to be random (some case it occurs and some other cases in the same project with the same settings it doesn't)
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
