2024-01-31
04:02 AM
2024-02-04
10:59 PM
Hi there,
Could you please assist me with the site plan view? It's showing some of thing that I've done it in the ground floor for example dimensions and the other hand I need to show my walls and windows and doors ,etc.
plan
Solved! Go to Solution.
2024-01-31 04:12 AM
Turn on the layers you want to see and turn off those that you don't.
2024-01-31 04:12 AM
2024-01-31 04:15 AM
Thanks Barry
2024-01-31 04:21 AM
Hi! You need a separate layer for site plan dimensions and notes. Use layer combinations. You might also need to do a Composite view in the layouts with multiple levels on top of each other.
If you need shadows You can also add a top view from 3d documents into your layout composition
2024-01-31 08:02 AM
Hi jl thanks for the reply. I have turned on the layers that I want to see but when I click on the ground floor and back to the site plan It's gone.
2024-01-31 08:05 AM
Just skip the question above. The problem is resolved. Thanks
