SOLVED!
site plan
Hi there,
Could you please assist me with the site plan view? It's showing some of thing that I've done it in the ground floor for example dimensions and the other hand I need to show my walls and windows and doors ,etc.
 plan
1 ACCEPTED SOLUTION
Solution
Turn on the layers you want to see and turn off those that you don't.
5 REPLIES 5
Solution
Thanks Barry
jl_lt
Ace
Hi! You need a separate layer for site plan dimensions and notes. Use layer combinations.  You might also need to do a Composite view in the layouts with multiple levels on top of each other.
If you need shadows You can also add a top view from 3d documents into your layout composition
Hi jl thanks for the reply. I have turned on the layers that I want to see but when I click on the ground floor and back to the site plan It's gone.
Just skip the question above. The problem is resolved. Thanks
