technical issue archicad won't save print setting macOS
cocoloco
Hi! This is first time having this issue. We want to print on previously selected 17x11" horizontally.
When I go to setting, archicad makes mistake and shows horizontal with picture of vertical, and if I select vertical it shows horizontal picture..
Now I select horizontal because obviously that is what I want... after clicking OK and go to print, again it does not print vertically and split the layout in 10 pieces.... THEN I go back to setting , and noticed the setting of horizontal is not saved!
How Is this possible. How do I fix it?
UPDATE: restarting fixed pdf file saving... however page setup mixing horizontal vs vertical is still switched.
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
0 REPLIES 0
