Lingwisyer
Guru
GDL - Layout Page Size
Hi all,
Is there some way to tell what the page size of a layout is? Or maybe read the Master Layout Name?
Ling.
5 Replies 5
There is autotext for the <LAYOUTNAME>, which you can use in GDL, but you can't see or do anything with the actual value (i.e. can't split the text to get the page size).
I see nothing at all for layout or master page size.
Lingwisyer
Guru
Yeah, I searched through the manual for something useable to no avail...
vlahtinen
Can you use <MASTERLAYOUTHEIGHT>, <MASTERLAYOUTWIDTH> and <MASTERLAYOUTNAME> autotexts? Explained here: https://help.graphisoft.com/AC/27/INT/_AC27_Help/070_Documentation/070_Documentation-69.htm
Lingwisyer
Guru
Autotexts cannot be used for anything except direct text output.
Yves
Only drawing title objects can access layout dimensions
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
