‎2022-02-08 08:13 AM - edited ‎2022-02-08 08:15 AM
Hi Team,
I am trying to create a tag for our Wall Types for our office. We have an existing tag, but are looking to overhaul our template, and are now including some extra information in the title of our wall types. As a result, the label now pulls the extra ' : ', which we are hoping to avoid, only showing the text string previous to the ':'.
I have limited knowledge of GDL, only really extending to copying what already exists! I've done some research, and had a play with that I've learnt, but still can't get the label to show correctly.
Can someone point me in the right direction (code attached below)?
Thanks!
If UseFillasTag or AutoId then
TempName = WALL_COMPS_NAME
len = strlen(TempName)
tex1num = strstr(TempName, " ")
if tex1num > 0 then
tex1a = strsub (TempName, 1 , 1)
tex2 = strsub (TempName, 1 ,tex1num)
tex1 = strsub (TempName, tex1num+1,len-tex1num)
if strstr(tex1a, "1") > 0 then Tex2 = tex1
if strstr(tex1a, "2") > 0 then Tex2 = tex1
if strstr(tex1a, "3") > 0 then Tex2 = tex1
if strstr(tex1a, "4") > 0 then Tex2 = tex1
if strstr(tex1a, "7") > 0 then Tex2 = tex1
len = strlen(Tex2)
if strstr(tex2, "PRIMARY") > 0 then Tex2 = strsub (Tex2, strstr(tex2, "PRIMARY")+8,len-strstr(tex2, "PRIMARY")-8)
len = strlen(Tex2)
if strstr(tex2, "WALLS") > 0 then Tex2 = strsub (Tex2, strstr(tex2, "WALLS")+5,len-strstr(tex2, "WALLS")-5)
len = strlen(Tex2)
if strstr(tex2, "WALL") > 0 then Tex2 = strsub (Tex2, strstr(tex2, "WALL")+4,len-strstr(tex2, "WALL")-4)
else
tex2 = TempName
endif
tex2num = strstr(tex2, " ")
if tex2num > 0 then Tex2 = strsub (Tex2, 1,tex2num-1)
tex2num = strstr(tex2, "-")
tex2num = strstr(tex2, "/")
tex2num = strstr(tex2, "(")
if AutoID = 1 and WALL_COMPS_NAME = "" then
else
TX = Tex2
endif
endif
EDIT: Using AC22 on Windows.
‎2022-02-08 08:49 AM
I am assuming your wall composite name is something like... P1: extra_description_here
I think it is because you are doing the string search (STRSTR) for a space " " after the colon instead of the colon ":" itself.
So the number of characters you are returning to tex1num is one more than the colon.
You are then using that string position number to get the substrings (STRSUB) from the composite name.
So search for the colon and/or adjust the number of characters you are using in the STRSUBs
I may be wrong, but that is my hunch.
‎2022-02-08 10:33 AM
Thanks Barry! That worked a treat!
This may be a stretch, but would it be the same for a surface label too? Hoping to do the same with the standard AC Surface Label, but can't see a similar code to what we had in the Wall Tag to make the update. Hoping to achieve this:
Rather than this:
! Functions:
! - Offered Tools: Wall, Slab, Roof, Shell, Column, Beam, Mesh, Morph Door, Window, Skylight, CWFrame, CWPanel
! - Content: Material of Surfaces
! - Size: paper size
_isPreview = (GLOB_CONTEXT = 5)
_paperToModel = GLOB_SCALE/1000
! resizing paper size parameters values to model length
widthTextBoxContent_mm = widthTextBoxContent_mm * _paperToModel
widthHead_mm = widthHead_mm * _paperToModel
heightHead_mm = heightHead_mm * _paperToModel
gosub "install_label_position"
if not(_isEnabledContent) then
! - Offered Tools: Wall, Column, Slab, Roof, Beam, Shell, Skylight, Mesh, Morph
call "label_placeholder" parameters all bitAvailableTool = 32+64+128+256+1024+4096+262144+1048576
end
endif
gosub "collect_content"
gosub "position_and_draw_label"
END !END !END !END !END !END !END !END !END !END !END
"install_label_position":
! Label positioning - global behavior for Marker form Labels
! - origin is where AC gives, the table begins with top left anchor
! - orientation is rotated with the parent structure by default
! - without AC Arrow
! - drawing the full symbol marker form
! - the origin is at the arrow peak
! - rotating with parent elem direction
! - Reference Point is cordinated by user
! - with AC Arrow
! - drawing only the head text
! - the origin is at the boundary
! - handling of rotation is belongs to AC (AC_CustomReadabilty OFF)
! - Reference Point is cordinated at Pointer tabpage
! LABEL_POSITION - position of the label
! - array[3][2] containing the coordinates of the 3 points defining the label position
! - the other transformations live in the label_marker_macro
nTrans = 0
if not(LABEL_HAS_POINTER) then
add2 LABEL_POSITION [2][1] + LABEL_POSITION [3][1],
LABEL_POSITION [2][2] + LABEL_POSITION [3][2]
endif
return
"collect_content":
nTrans = 0
_nRowLabel = 0
dim _sRowsOfLabel[][]
_sRowsOfLabel[1][1] = ""
dim _sContentStringsHead[][]
_sContentStringsHead[1][1] = ""
gosub "call_general_label_macro" ! returned text array, _nRowLabel, _sRowsOfLabel
_sContentStringsHead = _sRowsOfLabel
return
"position_and_draw_label":
! Text Style tabpage:
! LABEL_HAS_POINTER - built-in pointer ON/OFF
! - on/off 1 if the Use symbol arrow checkbox is checked, 0 otherwise
! AC_LabelPointerLineType - line type of the line of the arrow
! AC_LabelPointerPen - pen of the arrow
! AC_TextFont_1 - font name
! AC_TextSize_1 - text size
! AC_TextPen_1 - pen of the text
! AC_LabelTextBgrPen - text box background pen
! - 0 if opaque is off, the background pen otherwise
! AC_TextStyle_1 - font style in the settings dialog box
! - 0 - normal, otherwise j1 + 2*j2 + 4*j3 + 32*j6 + 64*j7 + 128*j8, j1 - bold, j2 - italic, j3 - underline, j6 - superscript, j7 - subscript, j8 - strikethrough
! - there is strikethrough and this global works well with define style{2} !
! AC_bLabelFrame - label frame on/off 1 if the label frame is checked, 0 otherwise
! LABEL_ROTANGLE - rotation angle using by AC (this rotation is not from GDL)
! AC_TextAlignment_1 - text alignment for full table
! - 1 - left aligned, 2 - center aligned, 3 - right aligned, 4 - full justified
! AC_TextLeading_1 - line spacing factor
! AC_TextCharWidthFactor_1 - width factor
! AC_TextCharSpaceFactor_1 - spacing factor
_angleParentDirection = 0
if not(_isPreview) then
_angleParentDirection = LABEL_ASSOC_ELEM_ORIENTATION
endif
call "label_marker_form" parameters AC_CustomReadability = AC_CustomReadability,
bAlwaysReadable = AC_bLabelAlwaysReadable,
! Position
iReferencePoint = iReferencePoint,
AC_LabelOrientation = AC_LabelOrientation,
angleParentPosition = _angleParentDirection,
! Paragraph Format
bEnablePrefixColumn = 0,
bUsePrefixColumn = 0,
bWrapText = AC_bLabelTextWrap,
widthTextBoxContent_mm = widthTextBoxContent_mm,
xFirstIndentParagraph = 0,
xLeftIndentParagraph = 0,
xRightIndentParagraph = 0,
xTabPositionParagraph = 0,
widthFactorTextBlock = AC_TextCharWidthFactor_1,
charspaceFactorTextBlock = AC_TextCharSpaceFactor_1,
iFixedHeightTextBlock = 0, ! fixed_height 1: the placed TEXTBLOCK will be scale-independent and all specified length type parameters will mean millimeters, !
!0: the placed TEXTBLOCK will be scale-dependent and all specified length type parameters will mean meters in model space
! Head apperance
sContentStringsHead = _sContentStringsHead,
bEnableCustomHeaderStyle = 0,
penTextHeader = AC_TextPen_1,
fontTypeHeader = AC_TextFont_1,
sizeFontHeader_mm = AC_TextSize_1,
iTextStyle = AC_TextStyle_1,
iAlignmentHeader = AC_TextAlignment_1, ! 1: left aligned, 2: center aligned, 3: right aligned, 4: full justified
sizeLeadingHeader = AC_TextLeading_1,
widthTextBoxOffset = AC_LabelFrameOffset * _paperToModel,
! Body skin list appearance
bUseTextBoxOnLine = 0,
! Label Head Representation
bEnableHeadSwitch = 0, ! Enable to switch the Show Label Head ON-OFF
bShowHead = 1,
iShapeHead = iShapeHead,
bFitFrameToText = bFitFrameToText,
widthHead_mm = widthHead_mm,
heightHead_mm = heightHead_mm,
bLinkSizes = bLinkSizes,
bShowHeadContour = AC_bLabelFrame,
penHead = AC_LabelPointerPen,
lineTypeHead = AC_LabelPointerLineType,
bShowFill = 1,
penForeground = _AC_LabelTextBgrPen,
penBackground = _AC_LabelTextBgrPen,
! Label Line Representation
distanceLabelHead_mm = 0,
bEnableLeaderLine = 0,
bDebug = 0
del nTrans : nTrans = 0
return
"call_general_label_macro":
! input:
! bShowCompositeID
! iIDPlacing
! sSeparator
! iIDText
! input variable
! totalRotate
! _drawContent - 0 - calculating only, 1 - draw text
! output variable:
! _widthTextBlock, _heightTextBlock
_nRowLabel = 0
dim tempsRowsOfLabel[]
tempsRowsOfLabel[1] = ""
call "label_content_macro" parameters iSelectedContent = _iSelectedContent,
iUnitLocal = _iUnitLocal,
bUseInSingleRank = 0,
bShow2D = 0,
iSurfaceToDisplay = iSurfaceToDisplay,
sPrefixSurface = sPrefixSurface,
sSuffixSurface = sSuffixSurface,
sCustomSurface = sCustomSurface,
returned_parameters _nRowLabel, tempsRowsOfLabel
! making from one dimensioned array to two dimensioned
idx = 0
for i = 1 to _nRowLabel
for j = 1 to 48
_sRowsOfLabel[i][j] = tempsRowsOfLabel[idx + j]
next j
idx = idx + 48
next i
return
Thanks for the help - really appreciate it!
‎2022-02-09 08:59 AM
I really don't know for sure.
It looks like the surface label CALLs macros to gather and arrange the information.
‎2022-02-16 10:21 AM - edited ‎2022-02-16 10:26 AM
Hi, I don't recommend modifying the AC Surface Label, it's too general for your task,
if you are only labelling wall composites.
Use WALL_COMPS_NAME to get the composite name, then use the STR functions to take it apart.
