RHF55
Hack the Surface Label
I would like to edit the Surface Label 25 to show the text of a surface before a delimiter. For example:
Surface Name is TC:Timber Cladding
Label to shown only TC
This is the code I have used to get this working on a wall label i wrote a while ago:
!======split
len = STRLEN (string)
iDotPos = STRSTR (string, sep)!sep is the seperator
code = STRSUB (string, 1, iDotPos - 1)
mat = STRSUB (string, iDotPos+1, len-iDotPos)!material
if display_txt = 'code' and code<>"" then
string=code
endif
if display_txt = 'mat' then
string=mat
endif
But I cant figure out where to catch the surface name and split it in this object. I think it might be happening in the macro label_content_macro. Any wizards out there that can figure this out??? @Barry Kelly ?
Of course this would not be required if GS would give us an ID field for surfaces the same as building materials.
Operating system used: Mac Intel-based 12
22 Replies 22
That is interesting.
It is the same format for the command, just STRSTR instead of CONTAINS.
I just checked the GDL reference PDF in 25 and it is STRSTR there.
I never noticed that in the Helpcentre website before (but I wouldn't have been looking for it specifically).
That website is actually out of date now and is no longer being maintained, just left as a reference I assume.
The Archicad help is now here on the Community but the GDL help is only found as a PDF in the application folder or the GDL Centre website here ... https://gdl.graphisoft.com/ (where it is also STRSTR).
RHF55
Here is the hacked label if someone needs it. Pretty simple but very useful for us.
If you pimp it further, post back with your changes.
Thanks for your wizard help @AllanP & @Barry Kelly
Lingwisyer
Guru
Anyone know if _sContentStringsHead contains bMat and / or bMat_ID?
ps. The Skin List Label uses the same macro structure so it would seem that it can. Just need to figure out how...
Lingwisyer
Guru
I have gotten it to show bMat_ID, now I just need to figure out how to get it to only show the first/last ID for composites rather than the full contents list.
Lingwisyer
Guru
The contents macro has an odd return when it comes to the BM of columns...
Maybe that is when the Skin List Label is not available for columns...
Ling.
ps. The BM_ID return seems to be empty in AC28+...
Lingwisyer
Guru
Turns out that the Label Content Macro has a bug when it comes to surfaces...
If you flip a wall, the label inverts the inside and outside...
Ling.
Benjamin Dani
Dear Ling,
Thank you for your feedback about Labels.
It seems like an incorrect behavior, however it would be great to know the exact settings you used and the environment you were able to experience this error.
I would like to ask you to create a ticket on our Support Site and describe the issue in detail, so our technical experts can investigate this further.
Thank you in advance!
Best regards,
Dani Benjamin
Technical Support Engineer
Lingwisyer
Guru
Looking more into it, it is less a bug, more an inconsistent behavior and UI issue. The macro pulls Wall_Mat_A and Wall_Mat_B which have an origin direction, which is relevant for doors and windows, and hence swap if a wall is flipped. I have detailed it in ticket #282137. I will see if the Wall_Flipped parameter can be used to make my BMat return consistent with the displayed surface. The macro UI is for GS to fix...
Ling.
@Benjamin Dani
If this is the way we should be submitting support tickets, could we please have that page fixed so that it shows the ticket types as shown in the how to submit article.
Every time I have tried to use it, there is no "Product Support' Option.
I have even tried in a new browser and accepted "all cookies" and it is the same.
This is what I see ...
Lingwisyer
Guru
I submitted a ticket, including a link here, yesterday under Learn Portal as it was the closest to being on topic... I got a reply from Ashley Clayton containing a link to this forum as well as one to the submit request page... *facepalm*
