GDL
How to use Autotext in IF statement condition?
LeeJaeYoung
aa = "<NOTES>"
if  aa = "222" then
      text2 0,0, 11111
endif
This if statement doesn't work.
The intent is to lock the GDL.
They say they want to prove that they belong to our company by putting in the company name and phone number and making it not work if it is different from this.
If not, I would like it to be.
As I tested, the value is not changed, but only calculated with "<NOTES>". The number of characters is 7, and the values of strsub 1 and 2 are "<N".
It seems that there is a way to get the value from request etc.
Is this an unsolvable problem?
Should I add it to my wishlist?
AC27 on window 11
2 ACCEPTED SOLUTIONS
Jochen Suehlo
You cannot work with Autotext in Operations in GDL. You only can display autotext.
Attached an object which requests all autotexts.
https://download.b-prisma.de/objekte/Autotext-Selector.gsm
Jochen Suehlo . AC12-29 . MAC OSX 14.4 . WIN11
GDL object creation: b-prisma.de
Jochen Suehlo
Have you seen this Website: https://gdl.graphisoft.com/tips-and-tricks/display-properties-with-labels
There is shown how to work with properties. Is that what you are looking for?
11 REPLIES 11
LeeJaeYoung
DIM autoTextListArray[]
n = REQUEST ("AUTOTEXT_LIST", "", autoTextListArray)
 Looking at which gsm file can I create this interface?
ui_style 0, 1
ui_outfield "Select Property", 10, 10, 100, 20
ui_Style 0, 0
ui_style 0, 1
ui_Style 0, 0
ui_custom_popup_infield "myProperty",
70, 30, 370, 20, ! X Position, Y Position, Width, Height
1,
3,
1,
_displayName,
autoTextListArray    !! This is error
AC27 on window 11
runxel
Hero
GDL sadly can't "see" Autotext...
POSIWID – The Purpose Of a System Is What It Does /// Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
Sorry, but how can I see this code?
I would like to know how to display a list in an interface.
ui_style 0, 1
ui_Style 0, 0
1,
3,
1,
_displayName,
autoTextListArray
AC27 on window 11
Jochen Suehlo
Hi there,  is there a way that I can see all listed autotexts?
@Domagoj Lukinic wrote:
Hi there,  is there a way that I can see all listed audiotexts autotexts?
I am not quite sure what you mean.
There is no list that you can print out if that is what you want.
Just expand the list you show in your image and you will see them all.
Better still, just start typing something in the search at the top to see what might be applicable for what you need.
No no no, I was asking is there a GDL object like Joachim Suehlo made that has a dropdown menu like that one that has listing of all autotext-s like property's
Jochen Suehlo
What do you need additionally to the object "Autotext-Selector"?
Hi there, I would need list of custom property's and general parameters...
