GDL
I'm trying to make some background fills. What should I do?
LeeJaeYoung
DEFINE TRANSLUCENT_FILL "DD" FILLTYPES_MASK 7,0,0,0,0,0,0,0,0,0
or
DEFINE SOLID_FILL "DD", FILLTYPES_MASK 7
SECT_FILL "DD",19,19,1
It says there is no problem with GDL, but it doesn't seem to be created.
What's wrong?
AC27 on window 11
you can use it for 2d scripts
and then once placed, it gets added to the fill list (in italics to indicate its made as part of a library part)
and it gives an attribute id of -1
but
if you put the code in a different library part,
that library part creates the fill  when the library is loaded,
and it can be used in a different library part.
I have been using ArchiCAD continually since ArchiCAD 4.5, 4.5.5, 5, 5.1, 6, 6.5, 7, 8, 8.1, 9, 10, 11, 12, 13, 15, 18, 21, 22, 25, now testing 28
Member of Architalk since 2003, but missed the migration to Graphisoft.
9 REPLIES 9
AllanP
you cannot use a fill defined in the script
https://gdl.graphisoft.com/reference-guide/directives
Inline fill and line_type attributes (defined in master script or 3d script) are not accepted.
Then, where is define Fill used?
AC27 on window 11
for floor plan fills
(2D script for 2d Objects)
text2 0,0,ind(FILL, "DD")
I can't test it in 2D script?
AC27 on window 11
but
thank you
I thought -1 was a failure... ^^
Have a happy time.. ^^
AC27 on window 11
also
most people set up a MASTER_GDL script to create these fills
https://gdl.graphisoft.com/reference-guide/inline-attribute-definition
but this method creates havoc when managing Attribute ID's.
so be very careful when using this method..
using library parts to create a fill places it in the lowest available ID in the attribute list.
making a fill using the fill menu places it after the highest ID in the attribute list.
kuvbur
Since AC 22 you can use global parameter GLOB_FILL_INDEX_SOLID or GLOB_FILL_INDEX_BACKGROUND without Define
just SECT_FILL GLOB_FILL_INDEX_SOLID,19,19,1
Structural engineer, developer of free addon for sync GDL param and properties
thank you so much. ^^
text2 0,1,GLOB_FILL_INDEX_SOLID
text2 0,0,GLOB_FILL_INDEX_BACKGROUND
AC27 on window 11
