We value your input!
GDL
Is it possible to make http GET requests withGDL?
Mihalcea Bogdan
I need to read from an API which gives me a JSON or TXT containing information like dimensions, price, barcode etc.
Can I make this with GDL or I have to make an AddOn?
8 REPLIES 8
Peter Baksa
Hi Mihalcea,
You can read local files with GDL but for HTTP requests you will need to write an add-on.
Péter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
Mihalcea Bogdan
Peter wrote:
Hi Mihalcea,
Is it possible to create a GDL Addon for such requests?
Lingwisyer
Guru
Possible, yes.
Will GS code one, probably not anytime soon unless there is huge demand for it.
If you really need it, your best option is probably to write one yourself or hire someone to do it for you.
Ling.
Mihalcea Bogdan
Lingwisyer wrote:
Possible, yes.
Ling.
Any documentation on how to make GDL Addons ? Can I make in C++ API GDL AddOns?
runxel
Legend
Not much, really. The documentation is super sparse.
The best thing next I know off, is my own documentation and template I made out of frustration.
Seems a bit like GS doesn't want to support that in the future.
People like the great Ralph Wessel also campaign to not develop any new GDL Add-ons, since they are so limited (see note below). Instead I think he and others switched to use the regular C++ API and then "fill in" objects. This however has other drawbacks of course (e.g. the Add-On has to be tailored to the object).
Beware:
GDL Add-ons are very limited and can not interact with the project or communicate with other add-ons. They are truly independent.
You should just use them to offload heavy tasks or computations you can't do in GDL (like bitwise calculations or I/O).
Making HTTP request would surely work as well.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
Mihalcea Bogdan
@runxel
Pure gold what you shared on your GitHub. I feel you with the frustration part!
runxel
Legend
Mihalcea wrote:
@runxel
Thank you for the kind words! I hope it will be helpful for others.
Peter Baksa
If the HTTP API sends data that might change after an object is placed, the objects would need to be rebuilt (executing the GDL request) each time they are drawn on the screen or a layout. I am not sure whether a GDL add-on can do this, please consult the developer forum or ask developer support.
Péter Baksa
