GDL
Is there any problem if h in prism_ is used as a negative number?
LeeJaeYoung
PRISM_ n, h, x1, y1, s1, ..., xn, yn, sn
Even if I use addz, should I not use negative numbers?
AC27 on window 11
I have used negative heights with no problems.
Or you can MULz -1
1 REPLY 1
Or you can MULz -1
