rav668
Opening symbol 21 Object
I am looking for source code of object named in the topic. Is there any way to obtain sourcecodes of objects made by GS? I would like to make some improvments on my company's own use.
Thanks in advance,
Rav
4 Replies 4
runxel
Just open it?
Select it in the view, press CMD+shift+O
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
rav668
runxel wrote:
Just open it?
Problem is that the scripts are empty, so I am looking for help here.
Erwin Edel
It calls the object from the Master script.
EPS = 0.0001
if GLOB_SCRIPT_TYPE <> 7 & GLOB_SCRIPT_TYPE <> 8 then
	call "slabOpeningSymbol_m" parameters all iSymbolType		= 1
endif
Just open the slabOpeningSymbol_m object by highlighting the name and using CTRL+SHIFT+O or CMD+SHIFT+O.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
rav668
EPS = 0.0001
endif
Thank you very much that is what I've been looking for
