GDL
Sensitize gdl object to story level
Bhtsz_pyd
Hello, I'm new to Gdl.
I have an object in my hand. I want to make a gdl object where I can choose which floor level this object will be at. However, I could not write a suitable code for this. There is the feature I want in the elevator object, but the gdl codes were too complicated for me. Which command should I use for this?
Thank you.
7 REPLIES 7
MF BIM
Hello @Bhtsz_pyd ,
You would need to REQUEST the STORY_INFO global variable. It holds info on all stories including the names, elevations and heights.
n = REQUEST("STORY_INFO", expr, nStories,
            index1, name1, elev1, height1 [,
            index2, name2, ...])
https://mfbim.fr | https://youtube.com/@mfbim | My GDL course on Udemy, try it !
AC24 FRA 7600 - AC26 FRA 4027 | MacBook M1 Pro
Bhtsz_pyd
Thank you MF BIM for your reply.
Obviously I tried that, but that's where your problem starts. What I want to do is to create a parameter that I can choose between. Ground Floor Plan, 1st Floor Plan, 2nd Floor Plan and link the position of the object to that floor. With the code you mentioned, I can get data such as story name or story height. I can also write it to the screen with the Text2 command. However, I cannot create a parameter that I can choose between them. Is there a sample video you can suggest about this? Creating a parameter similar to the “car position” parameter in the elevator object.
the additional code you need is:
n = REQUEST ("Story", "", index, story_name)
Returns in the index and story_name variables the index and the name of the current story.
n = REQUEST ("Home_story", "", index, story_name)
Returns in the index and story_name variables the index and the name of the home story.
you cannot physically move the object to a different story using the GDL code, but you can move where it appears in floor plan, and 3d Position using the code...
i.e.
n_current = REQUEST ("Story", "", index_current, story_name_current)
n_home = REQUEST ("Home_story", "", index_home, story_name_home)
nn_current = REQUEST ("STORY_INFO", index_current, total_stories, Index_Of_current, Name_Of_current, Elevation_Of_Current, Height_of_Current)
nn_home = REQUEST ("STORY_INFO", index_home, total_stories, Index_Of_Home, Name_Of_Home, Elevation_Of_Home, Height_of_Home)
nn_Ground = REQUEST ("STORY_INFO",0, total_stories, Index_Of_Ground, Name_Of_Ground, Elevation_Of_Ground, Height_of_Ground)
nn_First= REQUEST ("STORY_INFO",1, total_stories, Index_Of_First, Name_Of_First, Elevation_Of_First, Height_of_First)
nn_Second = REQUEST ("STORY_INFO",2, total_stories, Index_Of_Second, Name_Of_Second, Elevation_Of_Second, Height_of_Second)
and then you have the ability to calculate position/display based on designated story.
you can then have a parameter that has the story you wish to display
show_on_story
i.e.
values "show_on_story" "Ground Floor Plan", "First Floor Plan", "Second Floor Plan"
!2D Script
if show_on_story = "Ground Floor Plan" and index_current = 0 then
    !Show 2d content for ground floor option here
endif
if show_on_story = "First Floor Plan", and index_current = 1 then
    !Show 2d content for First floor option here
endif
if show_on_story = "Second Floor Plan", and index_current= 2 then
    !Show 2d content for Second floor option here
endif
I have been using ArchiCAD continually since ArchiCAD 4.5, 4.5.5, 5, 5.1, 6, 6.5, 7, 8, 8.1, 9, 10, 11, 12, 13, 15, 18, 21, 22, 25, now testing 28
Member of Architalk since 2003, but missed the migration to Graphisoft. Melbourne, Australia
@Bhtsz_pyd,
If you want to move the car then I would do it like this :
- Have an CarElevation parameter (length type)
- Have a CarPosition parameter (integer type)
- Request the story names and elevations after you requested the story info) and use VALUES{2} to display them as a drop down menu
- After selecting the CarPosition, calculate the sum of the elevations up to the chosen story
- Give that value to the CarElevation parameter to move the car
If you're new to GDL, you may need to go there to get some of the basics : https://gdl.graphisoft.com/gdl-basics
Bhtsz_pyd
@MF BIM @AllanP
Thank you both very much for your response. However, I think I asked my question wrong. The question I am looking for an answer to is to create an infinite loop “values{2}”
i.e.
values{2} “stryname” , 1 , Ground Floor Plan,
2, First Floor Plan,
3, Second Floor Plan
I can write this manually, but depending on the size of the project, sometimes it can be a 10-storey project, sometimes a 20-storey project. Every time I add a new floor to the project, I want that stories to be added to the parameter automatically.
Lingwisyer
Guru
You could PUT all of the values into a parameter through a loop using nStories from your Request. From there you can use GET to insert it into your VALUES{2}.
https://gdl.graphisoft.com/reference-guide/parameter-buffer-manipulation
n = REQUEST ("Story_info", "", nr, ss)
FOR i = 1 TO nr
!nr = STR ("%.0m", ss [4 * (i - 1) + 1])
!name = ss [4 * (i - 1) + 2]
!elevation = STR ("%m", ss [4 * (i - 1) + 3])
!height = STR ("%m", ss [4 * (i - 1) + 4])
FYI
Put only allows Numbers, so you cant use put on a story name that contains text.
but you can use:
dim s_info[]
dim s_index[]
dim s_name[]
n = REQUEST("STORY_INFO", "", nrstories, s_info)
for j = 1 to nrstories
  s_index[j] = s_info[j*4-3]
  temp_name = s_info[j*4-2]
  !!!!-------Note: you can't have the same name description for 2 different numbers, so this bit here for unique story names------!!!!
  if j > 1 then
    for ii = 1 to j -1
      if s_name[ii] = s_info[j*4-2] then
        temp_name = s_info[j*4-2] +"Story="+str(s_index[j],1,0)
      endif
    next ii
  endif
  s_name[j] = temp_name
next j
values{2} "stryname" s_index, s_name
