jc4d
Tips for saving writing code
Hello
I have a set of hideparameters that change depending on what option is checked (hope it makes sense)
Here i have an example in the parameter script:
		IF no_shelf_1 = 1 THEN
			HIDEPARAMETER "ShelfStyles_1"
			HIDEPARAMETER "Shelf_1_Bottom_Limit"
		ENDIF
		IF no_shelf_2 = 1 THEN
			HIDEPARAMETER "ShelfStyles_2"
			HIDEPARAMETER "Shelf_2_Bottom_Limit"
		ENDIF
		IF no_shelf_3 = 1 THEN
			HIDEPARAMETER "ShelfStyles_3"
			HIDEPARAMETER "Shelf_3_Bottom_Limit"
		ENDIF
As you can see in the example above, if I need to add more "IF no_shelf_x" then I have to modify the ShelfStyles_3 to ShelfStyles_x and  Shelf_3_Bottom_Limit to Shelf_x_Bottom_Limit and it is a real pain to do it by hand.
So my question is if there is a better way to do this using loops for example?
Juan.
runxel
Have "no_shelf" as an array parameter, so you can loop over all indices, then do some string manipulating:
for i=1 to vardim1(no_shelf)
	if no_shelf[i] then
    	foo = "shelfstyles_" + str("%~", i)
		hideparameter	foo
	endif
next i
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
jc4d
Thank you, I will test it as soon as I get a chance. 😊
