2022-08-05 01:16 PM - last edited on 2022-10-01 12:09 PM by Oleksandra Vakariuk
Dear All,
Today we have made Archicad 26 Update 3010 available. We have created packages for the INT, UKI, USA, GER and AUT versions so far and they all passed our tests.
The Check for Updates feature will notify end users about the new version. We will keep testing the rest of the language versions and release them as they pass the quality control.
You may read the List of Improvements here, while the update installers are available on the Downloads section of our website.
Should you have any questions or feedback, please let us know!
Kind regards,
Dani Benjamin
Technical Support Engineer
2022-08-05 01:38 PM
We're getting an 'Internal Server Error 500' when performing a check for updates from AC26UKI.
2022-08-05 03:33 PM
Thank you for your feedback!
I just tried an update check on my side from Archicad 26 UKI and it seem to be working.
I believe it was just a temporary error. May I ask you to try again?
I hope it will work for you!
If you still experience an error after that I would suggest to reach out to your local support to investigate the issue for you!
Kind regards,
Dani Benjamin
2022-08-05 10:29 PM
This build as far as I can tell addresses none of the issues we've raised here. When can we expect a road map to when GS will address these issues?
2022-08-06 06:24 AM
why is the RVT/RFA addon update page tab opening along with the main update tab?
2022-08-06 06:14 PM
It has always been like this since the RVT/RFA plugin was introduced. My guess is that since it is an add-on/goodie that is considered a feature GS decided that it should always check to see. It used to be worse since during 24-25? it always stayed in front of the Update Tab, now at least it brings to the front the Update one.
another Moderator
2022-08-23 05:31 PM
HI,
please the issue of font offset is very urgent
