NateLumen
Archicad crash - loss of data
Having an issue here. Here's how it goes...
1) I have two (or more) instances of Archicad open.
2) One of them freezes, so I force it to quit.
3) Archicad asks if I want to send a report. I do.
4) Archicad asks if I want to reopen. I do.
5) Instead of reopening a new instance of Archicad and recovering the file from backup, it just jumps me over to the already open instance of Archicad and the crash/reopen process ends.....
The backup file is functionally useless at this point, right? The only way to access it is during a "reopen", I've read.
Anyone else?
Nate Lumen
Apple MacBook Pro M1
Archicad 27-29
1 Solution
Eduardo Rolon
Backup should still be there:
  • Standard work flow after a crash is close all open instances and relaunch AC. You will see the file in the start up page.
  • Instead of reopening AC switch to the open one and select "New File" and click "Launch a New Instance" AC should give you the option to open the crashed version.
Read here:
https://community.graphisoft.com/t5/Modeling/Autosave-files-location/m-p/606048#M172114
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Go to post
1 Reply 1
Eduardo Rolon
Read here:
AC29 US/INT -> AC08
