5 hours ago
Hi. I have a trace reference loaded in my layout. I have selected the correct Document Options (print reference) however when I publish, the image falls behind other objects and isn't clearly visible. It looks great in my layout, and I have selected 'Reference on Top'. Attached are screenshots showing layout vs PDF.
Appreciate any help!
Josh
4 hours ago
Reference on top may simply be an on screen setting, and doesn't actually affect how the view publishes.
Can you achieve the same by overlaying two views in a layout?
Bring the one you want to the front with display order and set the background of the drawing as transparent.
