Hi Archicad users,
I am an Autocad user
) and I'm just starting using Archicad and I have some questions for you guys. I tried to find answers in the help but I didn't find anything.
So first question: when you already had created a door, how do you change the orientation of the opening? I used the symetry but it just work in one way. So I used a rotation and a symetry after but I'd like to know if there is an easier way of doing it?
Second question: there is a door with a sidelite and the door just open one way so is there a way of changing the opening in the block option?
Third question: is there a way of creating block like in autocad so if I change one block it changes all the same blocks at the same time?
I hope there are not too retarded questions, i'm just a beginner.
Thanks
