Archicad Start Edition
mtron
Archicad Start Edition (SE) is recommended for smaller architectural practices. To get started please contact your local distributor.
Based on the industry leading Building Information Modeling (BIM) technology of Archicad, its features have been tailored to the needs of smaller architectural practices. Archicad Start Edition includes all the necessary tools to create a BIM that is data-rich and able to produce all floor plans, sections, elevations, 3D views and details for a project.
Archicad Start Edition version Base Archicad version Features compared
Start Edition 2024 Archicad 27 SE 2024 and Archicad 27
Start Edition 2023 Archicad 26 SE 2023 and Archicad 26
Start Edition 2022 Archicad 25 SE 2022 and Archicad 25
Start Edition 2021 Archicad 24 SE 2021 and other versions
Start Edition 2020 Archicad 23 SE 2020 and other versions
Start Edition 2019 Archicad 22 SE 2019 and other versions
Start Edition 2018 Archicad 21 SE 2018 and other versions
Start Edition 2017 Archicad 20 SE 2017 and other versions
Start Edition 2016 Archicad 19 SE 2016 and other versions
Start Edition 2015 Archicad 18 SE 2015 and other versions
Start Edition 2014 Archicad 17 SE 2014 and other versions
Start Edition 2013 Archicad 16 SE 2013 and other versions
Start Edition 2012 Archicad 15 SE 2012 and other versions
Start Edition 2011 Archicad 14 SE 2011 and other versions
Start Edition 2010 Archicad 13
Start Edition 2009 Archicad 12
Start Edition 2008 Archicad 11
Start Edition 2007 Archicad 9
Start Edition 2006 Archicad 8.1
Start Edition 2005 (GER and CHE only) Archicad 7.0
File compatibility
File Open
  • Each Start Edition version opens the files saved by all previous versions of Start Edition.
  • Start Edition does not open files saved by full Archicad versions, except Archicad 8.1 and 9.
  • Archicad full versions open files saved by the corresponding Start Edition version (see the table above) and all earlier Start Edition versions back to Start Edition 2006.
  • Archicad full versions open files saved by previous Archicad full versions back to Archicad 8.1.
File Save
  • Start Edition versions save files of only their own version. This means that earlier versions of Start Edition won't open the file.
Comments
Nader
What does Archicad Full Version have to do with STAR(T) version in this sentence?
Thank you in advance
I think it is in the list so all 4 possible combinations are covered in the article:
1. START->FULL
2. START->START
3. FULL->START
4. FULL->FULL
