I am trying to find a solution for the following problem.
We have a 2D display issues with Archicad several times a day. (see screens below)
The only working solution is a reboot of archicad.
Sometimes the 3d windows doesn't display correctly
I have tried to upgrading the graphics card driver and i changing the advanced redraw options. It doesn't work.
The first two screens are 2d display and the last one is 3d display issue.
AC16-3270 NED FULL 64 + BIMX16
Windows 7 Professional 64
Intel Core i7 860 @ 2.80 Ghz,
10 GB Ram 1333Mhz (DDR3),
Nvidia Quadro FX 1800 768 MB
I'm using the latest version of the driver. And the case is fitted with two extra fans for cooling so overheating is not a problem. I tested different cards:
Nvidia 9800GT
Nvidia 460GTX
Nvidia 275GTX
ATI Radeon HD 4650
Quadro 1800FX
They all had the same problems.
Based on some things read at other threads, my question is:
What happens if you turn off the Aero thing in Win7?
Or try to around with its various settings?
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac29
