3D window display cutout problem.
Hi!
My Archicad started to do stupid things with the cutout in the 3D window. The cutout seems to be setted to a long stance from the "screen".
I tried to find the solution in the help menu or in the Archicad display settings. No clue. Have anyone had this problem before?
Thank You in advance!
Piotr
2 Replies 2
Erwin Edel
Are you modelling at a great distance from the project origin? That can cause problems, since ArchiCAD needs to calculate the model with very big numbers.
Could also be a hardware or driver issue with the GPU.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Daniel Kovacs
There are 2 things that usually cause this:
  • If you are working far from the ARCHICAD Origin, it can cause various errors in the 3D window, and all over your projects (this is what Erwin mentioned). This is one of the issues it can cause. You can find out more about Far from Origin issues and how to solve them in this Help Center Article.
  • In the 3D Projection Settings (In 3D right-click>3D Projection Settings), you have a value called (Target) Distance. If this value is too big or too small, the projection plane might intersect with the geometry, and cause this. Please check the target distance, and make sure it is around 5-10 m (like in the base template)
Please let me know if this helped you!
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
