2020-10-25 07:12 AM
2022-10-31 10:52 PM
Hello Graphisoft. I'm using versions 25 and 26 with the Spacemouse Wireless. None of the axis or button mapping works. Do you plan on fixing this? It's an important piece of hardware and I paid you $6300. That's a LOT more than a lot of other softwares that work great with this peripheral. What's the deal?
2022-11-01 06:25 PM
Join the chorus. I have been making regular complaints and repair requests for almost three years. Every year they will say, "we will fix it in the next update".
2022-12-12 08:54 AM
3Dconnexion Mouse still not working on AC 26 Silicon.
The 3Dconnexion menu is not visible using the buttons on the device.
The jumping is always present; less perceptible due to the speed of the computer.
My questions are:
Thank you
Configuration:
MacOS Monterey 12.2.1
McBook Pro Apple m1 Max 64 GB
AC 26 Silicon 4024 Int.
3Dconnexion Mouse wireless
2022-12-12 01:33 PM
They will never address anything with 3Dconnexion devices. The only thing left to do is to go to Budapest and have a sit-in in their lunch hall until someone fixes this.
I'll see you here when the next version comes out, and these things still don't work properly.
2023-02-24 07:07 AM - edited 2023-02-24 07:07 AM
Still not working.
It jumps and doesn't show the radial menu.
it doesn't happen in any other application.
https://forum.3dconnexion.com/viewtopic.php?f=23&t=39676&p=116838#p116838
2023-02-25 08:07 AM
I don't understand nobody in Graphisfot want to solve this issue.
The issue is real.
The problem is with Archicad on MAC
The navigation is not smooth, it jumps with interruptions of navigation, and the 3d mouse button doesn't work.🙄
The absurd think is that on the same computer using Archicad with Parallel on Windows........as you can see in the screen shot attached the 3d Mouse menu works and the navigation is smooth!!!! 😶
Please HELP US!!!!!!😰
2023-02-25 08:43 AM
Its way better to plugin USB than use the bluetooth option.
2023-02-25 08:58 AM
I use USB.
But have you tested the 3dconnection mouse on your computer?
2023-02-27 04:53 PM
I also have a whole list of issues with my 3D connexion device, and I always use USB. According to 3Dconnexion tech support, the issue is on Graphisoft's side, and its been there for a few years now.
The most incredible part is that it used to work back in the AC22-ish days. Then with one update, they broke everything, and there is no way to get on anyone's radar to fix this.
2023-02-28 12:16 AM
Been nagging support and GS dudes for years now to no avail. (It is even more horrible on Windows by the way. I'd even say it never worked back in AC22 or before.)
Always blaming on 3Dconnexion yada yada – of course Archicad is the only app where this crazy bogus happens.
I've lost any faith GS will ever unbug their software and support it correctly. Stop lying would be a start, too.
