AC 17 DOWNLOAD
Where can I find the download for AC17.
Looked on downloads page and all there is showing is hotfixes telling me there is not a version installed. Using dongle version.
New computer, old AC need to download it to new computer. Not upgrading.
Minh Nguyen
Thank you very much for the question!
I assume the version you need is USA? Please find the links below for Archicad 17 on Windows and macOS:
https://gsdownloads.blob.core.windows.net/archive/AC/17/USA/AC17-USA.dmg
https://gsdownloads.blob.core.windows.net/archive/AC/17/USA/AC17-USA64.exe
Please let us know if you need anything else!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
4 REPLIES 4
Try here.
http://www.graphisoft.com/downloads/archicad/install/AC17/USA
I just change the version number and nationality in the link to get what I want.
I really don't know why Graphisoft don't have a clear link to all of the older versions - or maybe I just can't see it.
I can easily find links to all the old add-on, etc., just not the actual program.
The page is a 404 error, I tried that earlier.
Eduardo Rolon
Looks like the archive starts with 18.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Minh Nguyen
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
