Installation & update
AC13 installation problems
After installation AC13, can not run project
appears message
TexEngine.dll file must be available to run the application!
Do you have any suggestions what to do
7 REPLIES 7
This problem with the TextEngine.dll file seems to occur fairly often. The advice seems to be to try uninstalling ArchiCAD, then disable your anti-virus temporarily, and try reinstalling again.
Hope you get it sorted.
Hi all.
After I've formatted my harddisk, I tried to reinstalling AC13, but I have this error message. (check picture).
I copied whole directory ArchiCAD in C:Program Filies/ Java, hope that will works, but the results is the same.
I've updated Java, but still not work.
How should I proceed, so that the program can be installed?
thanks in advance
Can anyone help me, please?
well, it seems that nobody want to answer my question...
Here is an article about ArchiCAD 13 install problems.
Check the section about Java and see it that applies to your situation (uninstall all java, restart, reinstall AC).
Thanks Laszlo, but I can't see the link to the article.
Ooops, sorry.
Here it is:
http://www.archicadwiki.com/ArchiCAD%2013%20Install%20Problems
