Ah, mystery solved, I just replied to your other post
The grass feature is best used in small areas, yep!
If you want to use it, what I've done in the past is make a single morph plane on the bit up close to the camera with a grass surface that has the feature and use a grass surface without the feature on the mesh.
www.leloup.nlArchiCAD 9-29NED FULL
Adobe Design Premium CS5
