2025-03-03 08:43 AM
Configuration Manager runs the deployment with the SYSTEM account. Software is installed in maintenance window in the night time, no user is logged in on machines. Computer labs, about 700 machines with 2 AC language versions.
Previous AC versions have worked fine with the silent install switches. The latest one usually, close to 100% of cases fails when run as System and nobody logged in on the machine. Installbuilder log is usually stopped in "Creating folder" steps, might have freezed mid folder name. Installer is stuck at about 420Mb of memory usage in task manager.
Rerunning the deployment then again usually runs fine. So something in the Installbuilder is not ok with SYSTEM account and maybe that nobody is logged in a machine. I also have the same problem with other Installbuilder created installers, Cinema 4D comes to mind as another that causes extra activities to it staff.
Am I the only one facing this issue or has anyone else seen this?
Solved! Go to Solution.
2025-03-04 02:58 AM
Is it anything to do with this (I have no idea what it is all about).
2025-03-04 02:58 AM
2025-03-04 07:27 AM
Thank you, that did it. Have to remember with other Installbuilders too:)
