Installation & update
AC9 file "Created" dates change
Craig Bagley
While searching through some old AC9 project .pln files, I’ve noticed that the file "Created" dates got changed from time to time, and I can’t find what may have triggered the changes. Has anyone experienced this? In all cases I can track the changed dates to times I was working on the projects.
"Modified" dates always change with each "Save", of course. But why file "Created" dates?
This has all happened on a 15” PowerBook G4 running Leopard, and has happened to several AC9 .pln files and PM .lbk files over the course of about 9 months before I switched to AC11. I also notice that the backup .bpn file "Created" dates changed to match their corresponding .pln files.
The problem isn’t apparent with later versions of AC.
This obviously isn’t an issue I’m losing sleep over, but if anyone has experienced this phenomenon and discovered what triggers it, a reply would be appreciated.
AC27 USA/Build 5030 16" MBP
Maybe when you copy a file from one hard drive to another, that copy is created at that time, so its "Created" time changes.
The BPN of course matches the date since it is nothing but the same file with its extension modified from PLN to BPN.
Craig Bagley
Thanks, Laszlo.
I don't recall copying from one hard drive to another. Maybe this is some unintended interaction between AC9 and the operating system. I'm hoping someone else has experienced the problem.
