2017-07-14 08:43 PM
2017-10-16 05:48 PM
laszlonagy wrote:Thank you very much. I will wait for your answer.
In that case, that is a very good question.
I will forward this issue to GS HQ.
2017-10-16 06:00 PM
2017-10-16 07:33 PM
laszlonagy wrote:Yes I understand. Thanks for your help.
I will not be able to give you an answer.
I am just forwarding the issue to GRAPHISOFT so that they know about it.
2017-10-24 09:56 AM
2017-10-30 06:32 PM
dkovacs wrote:I can not believe. Such a bad news
Since HP stopped supporting some designjet printers for Windows 10, they won't work with ARCHICAD 21 either. You can find out more about this here:
https://helpcenter.graphisoft.com/troubleshooting/setup/archicad-21-install-and-startup-troubleshooting-guide/#HP_Designjet_printer_does_not_work_with_ARCHICAD_21_on_Windows_10
2017-11-02 06:31 PM
2017-11-03 01:55 AM
AndrisL wrote:As mentioned in the link Daniel posted, Archicad 21 is now Windows 10 compatible so uses the Windows 10 drivers which your printer does not like.
Sorry, but something is not logical here.
I also have the same problem.
If the printer works with both ArchiCad 20, Excel, Word etc., but does not work with ArchiCad 21, then how can you blame Windows 10 or the drivers ?????
2017-11-03 03:58 AM
2017-11-03 04:08 AM
