Installation & update
ARCHICAD 21 IS NOT PRINTING ON HP DESIGNJET 500
Takis
Hi, I am trying to print to HP Designjet 500 but there is a driver conflict.
Driver 6.1 for the above printer is not recognized at all by Archicad.
The newest driver version 8.1 it is recognized but printer gives error 61.05.
Operating system: Windows 10x64
Archicad 21
Can somebody help please?
Takis
18 REPLIES 18
laszlonagy wrote:
In that case, that is a very good question.
I will forward this issue to GS HQ.
Thank you very much. I will wait for your answer.
I will not be able to give you an answer.
I am just forwarding the issue to GRAPHISOFT so that they know about it.
Yes I understand. Thanks for your help.
Daniel Kovacs
Graphisoft Alumni
Since HP stopped supporting some designjet printers for Windows 10, they won't work with ARCHICAD 21 either. You can find out more about this here:
https://helpcenter.graphisoft.com/troubleshooting/setup/archicad-21-install-and-startup-troubleshooting-guide/#HP_Designjet_printer_does_not_work_with_ARCHICAD_21_on_Windows_10
Daniel Alexander Kovacs
GRAPHISOFT
I can not believe. Such a bad news
Sorry, but something is not logical here.
I also have the same problem.
If the printer works with both ArchiCad 20, Excel, Word etc., but does not work with ArchiCad 21, then how can you blame Windows 10 or the drivers ?????
As mentioned in the link Daniel posted, Archicad 21 is now Windows 10 compatible so uses the Windows 10 drivers which your printer does not like.
Your other programs are probably Windows 7 compatible (but they will still work on Windows 10 although not certified for it) and use the Windows 7 drivers which your printer does like.
Could someone explain why this is a 'show stopper'? I thought that Adobe Reader / etc can still print PDF files to the Designjet 500 as stated in the Help Center article. If so, what's wrong with just saving PDF from ARCHICAD and printing in another app? Extra step, yeah, but at least this ancient (by tech standards) large format printer can still be used?
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
I agree with Karl - print to PDF.
I never print directly to a printer.
I always save (Publish) a PDF.
That way I don't have to start Archicad and load a file if I need a print, and anyone else that does not have an Archicad license can print as well without bothering me.
